check engine light (post hid install)
uh-oh_8_coupe
Car: 2008 A/C Dark Slate 2.5
followed instructions to install the lights from tech help. started to drive around and noticed my windows dont go up automatically and that i had check engine light on.
please help
SniperJoe
Car: 2008 Nissan Altima Coupe 3.5 SE CVT, Premium, Tech, VDC.
If you disconnected the battery - try this for the windows...Not sure about the check engine light.
1. Push the ignition switch to the ON position.
2. Open the window more than halfway byoperating the power window switch.
3. Pull the power window switch and hold it toclose the window, and then hold the switchmore than 3 seconds after the window isclosed.
4. Release the power window switch. Operatethe window by the automatic function toconfirm the initialization is complete.
5. Perform steps 2 through 4 above for otherwindows.
uh-oh_8_coupe
code was P0603PCM Keep Alive Memory (KAM) Error
gunna try the windows trick, ty
uh-oh_8_coupe
so should i just clear the code??
uh-oh_8_coupe
windows work now
uh-oh_8_coupe
anyone one??just erase code and fuhgettaboutit?
BlackNWhite
Car: 08 Altima Coupe
I had the same thing. I had the check engine light come on also. I disconnected the battery again... and the light didn't come on again.
Scott21384
Car: 2008 Altima Coupe 2.5S - Super Black
I had that light appear as well after HID install. I drove around for a day and all of a sudden it went away. I am not sure why.
shortys408
Car: '11 M37S
08 altima coupe 2.5s - *Sold*
i got rid of the light after disconnecting the battery and reconnecting it.
