Check Engine Light ON
Vrusski
i just bought a 96 240 base model and brought it home 400 mile drive and everything was fine. drove it today and the check engine light went on...how do i check the code?is there a codes page?help need to pass inspection soon cant with the light on.thanks
[s3]
Read the FAQ
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
http://www.ka24development.com/tech_info.html
Look for "ECU Reading / Resetting"
If that's not sufficient, then check 240SX.org, there's one on there as well...in the "FAQ"
- Brian
Vrusski
thanks man for the link, its really good help! ill check for codes tmw and see what comes up
