Check Engine Light on
pawprint
Car: 2012 Nissan Altima 2.5 SL w/technology package
Check engine light came on tonight on the way to the store. I have 3/4 tank of gas, haven't refuled in a week. Oddly the light came on the same time I hit 666 miles. Must be bad luck. I guess it's time for a Nissan visit. I'll keep you updated.
rjchoops
Car: 08 Rogue SL AWD
maybe your Rogue was built on Halloween.
philipa_240sx
If you want to save yourself a trip to the dealer, you can pull the diagnostic code and clear it yourself:
post5563535.html#p5563535
Make sure you write down the code so I can look it up for you.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Whoaa, slow down cowboy. :stickhit: This is what exactly happened to me a few weeks ago. There is no way my new Rogue ( in my mind ) is messed up yet. So I went to this forum and found out it may be because my gas cap was loose. Personally I thought it was because I always double and triple clicked til tank was full (when filling tank) hoping to get the full orange bars. But I vaguely remember I twisted my gas cap only 1 click. Actually I did that; Thinking it was sufficient.
Instead of the usual few days (2-3)and half a dozen trips, mine took more than a week and over TWO dozen trips in the city. Then the Service Engine Soon light went off. I read that it went away faster for other forum members, but I was patient and thank god it disappeared. No problems since. Been filling tank a couple times making sure I twist gas cap to 3-4 clicks. Back to normal.
Read the Rogue gas cap, it actually says the service light may go on if the cap is loose. :ohsnap
Surprise, surprise, I actually read that AFTER it happened when I was bored filling up. :blush:
Hope my experience may help. :yesnod :dogpile:
ps- I re-tightened, but I had to wait to refill the tank and wait awhile still. I speculate that this is because it needs time to re-adjust the pressure in a newly filled gas tank. Any experts out there please chime in as this is my layman view.
pawprint
Just got home from Nissan dealership. Here's what my receipt says. Mileage in: 671.
Scan system- retrieved code P0463 and P0725 - Engine speed and fuel level sensor/circuit performed confirmation procedure No 1st trip DTC code detect could not confirm - no problem found at this time. Reset NO codes at this time.
Well I'm not clear on what all that means, but the light is now off.
As I side note: I drive very little. I last filled up at Shell on April 4, 2010. I've driven 93 miles since then. I have not touched, changed or messed with the gas cap since April 4, 2010. (I purchased brand new on Dec. 15, 2009 with 42 miles on tachometer. Now I have 675 miles.)
The check engine light came on while driving to the grocery store, which is 1 mile away and remained on until Nissan Service did their thing. Also, the Rogue drives perfectly and I haven't noticed any differences.
Fortunately for me, the Nissan Dealership is 2 miles from my house. Their waiting room has free WiFi and coffee. I bring my laptop and I'm content. Doesn't bother me to wait, they are very nice.
philipa_240sx
There was a tech bulletin for P0463, but it only applied to "08 Rogue's.
Unless it re-occurs, I would not worry about it any further.
Return to “Rogue Forum”
