Check engine light on, new exhaust
turtl631
Car: S14
I jsut bought an S14. Its stock except for an HKS Super Drager exhaust. The check engine light has been on since I got the car, but it seems to run perfectly fine. Could the exhaust be causing this? Is there any way for me to make it turn off? Thanks!
k6kicker
Car: 90 300zx(tt) 95 240sx
im in the same boat as you man, i tried replaceing the O2 sensor but it didnt do ****, and as we dont have odbII in our car (well some of the later 95's did) we can't just stroll into autozone and have the little computer tell us whats wrong
silkk
Car: 94 B13
89 S13
07 S2000
check your vacuum lines and maf and other stuff that i can't think of right now
180fan
Car: 89 fastback
you try using the ecu to tell you what code you're getting?
Stuntman240
Car: 91 coupe
did the ground wire on the ehaust come off when u installed the new exhaust, if i am not mistaken (oon s13's atleast) the o2 sensor has only 1 wire, which means it is grounded to the exhaust, that might actually throw an 02 sensor code. also chec what code the comp. is throwing.
turtl631
Car: S14
I didn't install the exhaust, I just bought the car recently and it came with it. How do you check what code the ECU is throwing? How would I check the MAF, vaccuum lines, etc? Where is the O2 sensor grounded to the exhuast so I can try to check that?
Stuntman240
Car: 91 coupe
the ground is made by the o2 sensor being screwed in. on the exhaust (near the cat or on it) i believe there is a flat silver probably black w/ dirt or grease that goes from the exhaust to the chasis
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
http://www.zeroyon.com/techfil...5.zip
Here's an FSM, it'll have all the info you need for ECU code reading.
Assmunke
yea download that FSM it is all you need for most **** that goes wrong with our cars.
