jrunner »
https://forums.nicoclub.com/jrunner-u14679.html
Sat May 08, 2004 2:24 am
It has been my experience that the ECU for s13's (not sure about s14's) has 3 screws that need to be removed in order to flip the ECU around to read the LED lights. On my car, there was a screw above the ECU, one below, and one on the side farthest from you if you were sitting in the car facing forward. The screw that is above is hard to see, and even harder to reach. There may even be a fourth screw, but I only remember having to remove 3 to get that box to move.
It was a real pain actually, its much easier to use an analyzer, so if any of your friends happen to have one that works with 95+ nissans, I'd give them a call.
