maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Wed Nov 30, 2005 1:57 pm
Manufacturers are always coming out with PCM and TCM updates to solve certain drivability problems. It may be true that there is a TSB that recommends a reflash.
The reason I pointed to the O2 sensor and injectors as the posible problem is that your code indicates a lean condition in bank 1. First, an O2 sensor does (to a certain extent) help in governing your fuel mixture in certain rpm ranges. Second, that is the sensor that you have had replaced recently. Lastly, there is (as far as I know) only one fuel pressure regulator for the entire fuel rail, which leads me to believe that is the injector or the fuel control - otherwise bank 2 would show lean if it were a fuel delivery problem.
