MAF connector can come loose during air filter changes though, esp if the wiring is brittle.maxnix wrote:There is no reason to mess with MAF connector when changing the oil or air filter.
Look on page EC-40.grunze wrote:I have the manual but still haven't found anything on the reset. Will keep looking.
Oh........that ECM! Only looked at that page two or three times. Makes sense now and I know where it's located. Thanks Heath.Q451990 wrote:
Look on page EC-40.
Heath
Same thing happened to me a month ago on my G35. Infiniti service told me it would go out by itself after a couple of hundred miles. It went off after less than 100 miles.grunze wrote:96 QAfter an oil change and air cleaner(Nissan original) replacement today the check engine light(multifunction indicator lamp) stays on. This is undoubtedly because the connector to the air cleaner housing(?) was left off as the car was started 4 or 5 times and then quit as soon as the hammer mechanics tried to drive it. With the connector back on the car started but now had the MIL on. The boys disconnected and reconnected the battery with no success and then told me that it should go off after driving it. I have my doubts. Any advice? Thanks.
