I'm confused...if it's 0442, then "if your car blinked 10 times, then 4, then 4, then 4 again, you would have a code of "0442" but it seems like it would be 0444.marlin29311 wrote:Not always a couple of miles...mine has come on twice because of the gas cap (apparently no one in new jersey that pumps gas knows how to 'click' the cover... ) and it can take a few days for it to turn off. The first time it happened to me I took it to Nissan because I was mad that my car only had 2300 miles and it had been on for a few days, and the tech said that it was just the gas cap thing and the OBD system takes a few days to reset itself.
If you want to make sure that it is the gas cap issue, you can do the OBD check yourself - if you come up with the 0442 code, it's just the gas cap.
To take a reading without using an OBD II reader, you can do this...
1. Put the car into "on" without the engine started (aka, hit the ignition button twice without having your foot on the brake)
2. Wait 3 seconds for the car to do a systems check (you know this is done when all the lights except your service engine light go off)
3. Do 5 full accelerator press and releases in 5 seconds (floor your car 5 times in 5 seconds)
4. Wait 7 seconds.
5. Floor the accelerator again, and hold it there for 10 seconds (approx). Your service engine light will turn off.
6. When the light turns off, take your foot off the pedal, and get ready to count.
At this point, the service engine light will start blinking. It will give you a 4 digit code - the first number will flash slowly, followed by a slight pause, the next three numbers will flash quickly, all with a pause in the middle. 10 flashes means a number "0." So if your car blinked 10 times, then 4, then 4, then 4 again, you would have a code of "0442," which is your gas cap thing. Other codes can be determined by looking at a OBD II code reference sheet, which can be found by googleing it, or probably somewhere in the forums...
heh...you're right! I think i got caught up typing all of that and put at 4 instead of a 2...thanks for the catch, i'm going to edit it now...dpn wrote:
Thanks,
DPN
onmarlin29311 wrote:Not always a couple of miles...mine has come on twice because of the gas cap (apparently no one in new jersey that pumps gas knows how to 'click' the cover... ) and it can take a few days for it to turn off. The first time it happened to me I took it to Nissan because I was mad that my car only had 2300 miles and it had been on for a few days, and the tech said that it was just the gas cap thing and the OBD system takes a few days to reset itself.
4. Wait 7 seconds.
At this point, the service engine light will start blinking. It will give you a 4 digit code - the first number will flash slowly, followed by a slight pause, the next three numbers will flash quickly, all with a pause in the middle. 10 flashes means a number "0." So if your car blinked 10 times, then 4, then 4, then 2 (edited from 4) again, you would have a code of "0442," which is your gas cap thing. Other codes can be determined by looking at a OBD II code reference sheet, which can be found by googleing it, or probably somewhere in the forums...
Modified by marlin29311 at 3:32 PM 7/22/2008
