check engine light o2 sensor ???
fsflip13
Car: 1995 Nissan 240sx SE
my check engine light keeps coming on and when i check the codes they read the rear 02 sensor code and the egrc/solenoid code
does anyone think that putting a new rear o2 sensor in would stop these codes
has anyone had this problem and what was the outcome
it doesnt make sense to me because the ecu is shooting both of those codes so i dont really know if the o2 sensor is what is causing the problem
any help appreciated
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Chances are, if the ECU is throwing a rear o2 sensor code then yeah it needs to be replaced. Replace it, and then see what the ECU is telling you.
fsflip13
i wonder why the ecu was reading egrc/solenoid though?
