sam_vee »
https://forums.nicoclub.com/sam-vee-u106215.html
Tue Sep 16, 2008 12:30 pm
When keying in ignition (radio on, before engine start), all the lights (seat belt, overdrive... etc) are lit except for the Check Engine Light. We checked the Check Engine light bulb and is fine.
The smog test cannot be completed because the MIL status remains off. Assumption is that the faulty check engine light does not allow for the completion of emission diagnostic cycle to enable MIL status on.
Welcome any other suggestion for why engine light not coming on in ignition mode. Is replacing the whole cluster to correct the only way to get Check Engine Light back on?
Thanks in advance.
