OwnerCS wrote:The CEL with no codes when I turn on the ignition switch is the condition that has me stumped. When I start the I30 and any other Max I've had in the past, the CEL would not be on unless a code was also present.
The other item is the car can be started for a few seconds if the fuel pump fuse is pulled. If you insert the fuse and let the pump build up pressure, then remove the fuse before trying to start it will start. Leaving the fuse installed results in it immediately flooding out. The fuel return line has been blown out to rule out any return line or dampner obstruction.
Interesting. Clearly, the engine is getting too much fuel.
The ECU is controlling the amount of fuel injected by increasing/decreasing the width of the electric pulse that opens fuel injectors. Inputs from many sensors (MAF, MAP, TPS, ... ) affect this computation .... TPS comes to mind. TPS needs to be calibrated; is it possible yours got out of whack, somehow?
