Freeze Time wrote:Hmmm, from what Buzzman posted, he clears the code right before he tests it and it passes. I guess things are different in Canada. I live in California. How long will I have to drive my qx4 before it is ready to be tested? I thought the whole point of getting the OBD2 meter is so I can clear the code so it doesn't automatically fail.
It's hard to say what process will work where.
Here in Canada, each province has their own system/laws for emissions testing.
I'm guessing that in the U.S. emissions testing and standards are a state to state system, and not national.
In Ontario, emissions testing is nothing more than the tech sticking a reader on the OBDII port and recording the results.
The days where they shoved a probe up the tail pipe and actually checked what was coming out of the exhaust are long gone. Stupid really.
As long as the SES light is off and the ECU is not throwing codes, you'll pass.
If the SES light is on, they don't even test it.
So, to clarify what I do, yes, I erase the codes after driving the truck and warming it up etc.
Then they bring it in, do their readings, and I pass.
Funny enough, my SES light has been off for a while now.
My resonator and exhaust pipe rusted off, so I have been driving around with nothing attached after the muffler for a while now.
Not sure if that's a coincidence, but it makes me think.
I don't drive it much, or for long trips, but I do keep my window cracked open, just in case any exhaust finds it way into the truck from underneath.
I plan to fix it when the weather gets warmer.
Cheers.
