Wc240 »
https://forums.nicoclub.com/wc240-u133792.html
Mon Jun 15, 2009 2:08 pm
it would be better to know the exact codes(number), and its kinda hard to tell if not directly at the car but heres a starting point.for the fuel/air metering, id check your O2sensor(takes care of that code too) and clean the MAF. Check the connection to the purge valve, check to make sure your vacuum lines are routed properly with no leaks.Check your wires/routing to the knock sensor/make sure its plugged up.id start with that
