centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Tue Apr 03, 2007 6:03 am
To pass SMOG in CA, the CEL must function correctly, on with keys in on position and engine off and then turn off with keys on and engine on. This was easy for me to fix, I guess like the S13, the S14 has only four screws on the steering collumn, then two on top of the bezel, then 3 hold in the cluster. Very easy to get at the little christmas lights stuck to the back. FYI they were bulbs, not fuses, with strange contacts that make them look sort of like a fuse. I just pulled my cruise control bulb and put it in the hole for the CEL and it works great! I was happy to find no cut wires or fuses that needed checking. Just a hole where a bulb should have been. I never knew it was an orange colored light! A properly funtioning CEL is a good thing imho. FYI, the CEL has no self test or code of it's own. Yay me! I also fixed my TPS and bought a new CAS (old CAS was only half a sensor)! The real beach was taking out my s13 transmission again, drilling and threading holes in the bellhousing for the CAS and then putting it back together. Note to all putting an s13 transmission into an s14, it works and will be fine with SMOG but aside from just pulling and putting in a transmission, dont forget the following: drill the holes for your CAS, check all your posisiton sensors for continuity, swap the speed sensor, put in your short throw while its off the car, unstick and clean you drain and fill plugs all before installing the transmission or you'll end up doing it twice like me!
