mss5413 wrote:Yes it does light in the on position when the engine is off and goes off when the engine is running. But I don't understand how the dealership could still find codes in the computer. And why would it not light with a sensor disconnected?
Well, in that case, the only way you can verify is to pull codes yourself. It does seem strange that they pulled codes w/o the light being on. But from what I can tell, you engine light is working fine.
Just disconnecting the sensor for a short while, I'm not sure if that will throw a code or not, maybe if you left it disconnected a little longer.
Pull the codes yourself. Easy as that.
