Well, it can bend a connecting rod, or break a piston. But if the valves are seated, you can't get a force on them to bend, and if they're open, you won't develop a hydrolock. Jumped camshaft timing is where the valves will bend, when the pistons kiss them.yodawill2000 wrote:If they are leaking into the cylinder you will smell gas in the oil. Also theres the danger of hydrolock when you start it.A cylinder full of gas will bend the valves if it makes a stroke.
You're kidding right?yodawill2000 wrote:
I might add .. a knock sensor will NOT trigger a check engine light.
Actually they are $129 each on everything nissan/infiniti.NismoChi wrote:The knock Sensor is more like $60-$80 and there is only one on our car.And it is located under the IM, on top of the block. And yes, it is very labor intensive.
Look harderhttp://cgi.ebay.com/ebaymotors...wItemhttp://forums.maxima.org/showthread.php?t=487731 Also, yodawill2000 was right, According to the FSM, knock sensor will throw a code but WILL not cause a CEL.gr8scott72 wrote:Actually they are $129 each on everything nissan/infiniti.
Cheapest injectors i've found http://www.autopn.com/store/pc...28451hkchuen wrote:A friend's friend (a mechanic) promised to help me change fuel injectors and knock sensors... I need to buy the relevant parts though.
[1] Where can I buy 6 fuel injectors cheaply?[2] Thanks for the link for the knock sensor... is there 1 KS in the car or two?
Are there any other parts I need to buy?
Thanks!
