Darius »
https://forums.nicoclub.com/darius-u5470.html
Thu Nov 16, 2006 4:27 am
Ok I've been driving the car around (RB25) for a few weeks now and have occassionally (50%) been getting a check engine light that pops up. Typically, it will go away when I am on the gas and light back up when I'm off of it. When I am driving at a constant speed, it will flicker on and off randomly. I turn the car off and get the ECU to blink off the code and it always says 55. Correct me if I'm wrong, but doesn't that mean everything is okay? pssh, what does that car know about my life anyways?
There is no indication that the car is running irregularly except for the fact that I am getting about 10 mpg. I'm thinking it might have something to do with the coolant not being 100% bled, which I will do again tonight, or possibly my O2 sensor.
NOTE: I have to turn a switch on and off to manually ground my ECU relay so that my sensors get power. My ECU doesn't do it itself because there is something wrong there. But when I close the switch, it will start and drive.
