s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Sun Aug 29, 2004 2:26 pm
egr was prob not functioning fully due to lower backpressure. the bpt(back pressure transducer) needs backpressure to let the vacuum to the egr valve. if you took the egr valve apart and cleaned it, then it might work ok with the lower backpressure. that or you could block it off and stick a resistor in the egr temp sensor connector so the ecm thinks the egr still works:D
the ignition prob should be on the primary side of the coil. it prob wont be an issue with plugs, wires, cap, or rotor(i could be wrong). the primary side would be things like dist(internal spinny things), power transistor, ecm, or coil. you said you fixed it so i will shut up. what was it?
