96Qowner »
https://forums.nicoclub.com/96qowner-u19561.html
Tue Dec 06, 2005 7:27 am
At least you're not the only one. I bought my 96 with 147K on it, and it immediately needed the cam sensor and an O2 sensor - not terribly spendy. The MAF is relatively cheap - a genuine Do-It-Yourself job - you can get a used one through car-parts.com for less than $80.
The BIG cost is replacing the knock sensors, which requires labor-intensive removal of the plenum. As Q45tech pointed out ... that's when you have to (want to) do everything else - hoses, VC gaskets, plugs, etc, while the plenum is off. I had to do my plenum job because an inaccessable fuel hose started to leak in cold weather.
Don' freak out. You can stall the knock sensor job as long as you don't lug it too much.
I believe Q45tech has repeated pointed out that maintaining a Q will cost you 20 cents a mile or so, whether you like it or not - simply the cost of owning one of the best cars Japan ever built.
