3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Tue Jul 23, 2024 8:42 pm
Although unpleasant, you can always get the OBD-i code right from the ECU if you pull the pass side kick panel undo the 3 philips screws, and gently reposition the ECU so you can get at the mode screw. be gentle with the screw if you are unfamiliar with the procedure. You have to turn it to the stops, but don't gorilla it...
