yes...i follow this alsonametakennow wrote:Did you do the switch pressing procedure as follows?
Open driver's doorGet inShut doorTurn ignition to the "on" position (not ignition, car remains off)Open doorReach down and press the "door ajar sensor button" 7 timesShut doorStart the car
Seeing as you don't want a airbag to go off in your face...nametakennow wrote:The best plan is to go to a dealer and have them check the problem since airbags are a safety feature.
i confirm it is no problem for the airbag, it is because i change R33 airbag wheel, it is work before. but i got one time forget connect insert of airbag before i connecting battery, after that i got the signalnametakennow wrote:That's the only reset procedure. Take it to your dealer.
