squeefoo »
https://forums.nicoclub.com/squeefoo-u8899.html
Wed Jul 14, 2004 5:53 pm
After laying under the Q for awhile looking at what had to come out and knowing the %$#@er had to be replaced, I felt the rain of blessings from the Q gods. Pulling out the tape measure, I figured it out. Remove the pedals, pull back the carpet, and bore a 2" hole over the *&^%$#mn sensor. Worked great! Put in a 2" caplug with some undercoating and it's done. (about an hour)Forgot to tell you guys about this, it was lost to the mists of time 'til a Newbie jarred it loose. I used a 90 deg. adapter on the drill w/ a hole saw. Measure VERY CAREFULLY 2 - 3 X !!!!!!!!
