MySXisSlowerThanUrs »
https://forums.nicoclub.com/mysxisslowerthanurs-u104548.html
Wed Feb 04, 2009 7:11 pm
yeah pretty much, it wont be tooo smooth with the pull hammer but it will get it to the point where its safe to bondo, Bondo is easy, just make a small batch and lay it on there and use the cheese grader thing after about 10 minutes of bondo drying and take off the extra bondo, I do this cause it saves you alot of time on sanding..
Also when applying bondo on the holes try to use something on the inside of the Quarter panel so the bondo does get all over inside your car, Pretty sure it wont be to bad if you dont cover them up..
But yeah just take you time, youll have to do a quite a few layers but youll have to sand alot and its alot cheaper than any other method out there..
I cant stress it enough, Dont get pissed and frustrated about it, the bondo will always sand off if you put to much on!
Post pics, if you have a problemor just ask one of us, or me
also if you cant reach the quarter from the interior you can use the slide hammer all the way. its just IMO a little easier if you can get some of it pushed out from the inside
