Cheapest Tires/Brakes for 2015 Q60S
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
RomeWashington1
I need new tires and brakes for my cars. I'm looking to get the cheapest possible.. I found tires on TireRack.com for $592.86 - I tried searching Amazon but it seems to understand that my back and front tires are different dimensions.
Anyone who has any suggestions on how to find cheap tires please let me know. I would even buy them used if they were in good shape.
For the brakes I'll need the factory.
RicerX
Car: '20 Titan Pro4X
TireRack has always been a solid bet for me as far as new tires are concerned. Are you doing this for a lease return?
As far as brakes go, Tunerzstore.com is a good place for the factory brake parts. They have an OEM Infiniti parts section that will help you out.
RomeWashington1
Sorry for the late reply here!
I can't seem to find any used tires.... Would my car take the same type of tires as previous years G35 or G37?? I know I have 19" rims... Where would I be able to find used tires that would definitely fit?
Regarding the brakes thank you for suggesting Tunerzstore.com - Will mechanics still install it if I just bring them the parts? I feel like most Mechanics want to buy it themselves... I guess I'd have to go to a no name mechanic somewhere?
audtatious
If you have a 2015 Q60s with staggered 19" the front are 225-40-19 and rear are 245-40-19.
RomeWashington1
Thanks, so just find any tire with those dimensions and they will fit? Anyone know where I could find used tires?
Larz
Car: 2019 Q70-L RWD
Ermmm. remind me never to ride in your car. You realize that you are missing out on the performance and handling that makes your car worth driving in the first place, don't you? To answer your installation question, my dealer will install anything non-OEM I bring them including wheels, tires, brakemotive kit, headlamps, and the latest: a 4-note tuned cadillac horn. The drawback is they will not warranty anything that they do not provide, but the manufacturer will warranty the parts you buy.
audtatious
RomeWashington1 wrote:
Fri Oct 27, 2017 10:44 pm
Yes
If you can't afford the tires I'm not really sure why you have the car? There are cheaper vehicular options out there than can be maintained at a much lower amount than and Infiniti.
Not trying to bust your ballz...
Archangele
Car: 2004 350Z, 2014 Q60S
I have found that Tire rack online has the best prices. You are not going to find cheaper tires anywhere.
As for used. Don't do it unless they were from a car that died and they are practically new.
Believe me, the money you may save with cheap, used tires could cost you both the car and your life.
Ditto for brakes. In fact in most states it would be illegal to sell used brake components.
A set of tires for this car can be had for around $600 on Tire rack. Myself, I generally
use Yokohama or Bridgestone tires only on my Q60S or my 350Z. Tires and brakes
are two things you NEVER cheap out on! People who buy the Z car or a Q60 need to
research the cost of tires, brakes and maintenance. These cars are VERY unforgiving if
you skimp on maintenance. I know of a Q60S that has a ruined engine at only 34K miles because
the previous owner only changed the oil two times in 34K miles. Oh, they were
led to believe you can leave Mobil 1 in there for 15K miles.. NOT!
carldu
Car: 08 Titan
I run continental tires on another car. They offer good traction and handling. These tires are not pricey also.
Return to “Infiniti Q50 / Q60 Forum”
