cheapest and easiest way to increase boost?
mmashburn
Car: 1992 240sx
I have a redtop sr20 and i want to raise the boost from stock 7 psi to about 12psi. would it be better to get a cheap manual boost controller off ebay or can you get an HKS actuator that is rated at 12 psi.
tony/ka24de
put a thread on the wastgate and shorten the rod
ILikeMy240sx
Car: SR Power
home depot valve (MBC) I do not recommend this but I hear it works. Id stick with Hallman MBC or any other MBCs...
BaliLover
Cheapest and easiest? Just unhook the vaccume line from the waste gate. Safe? No. Cheap and easy? Yes.
FWIW, the Home Depot MBCs work just as well as any other MBC I've played with, but they're a tad spikey and tend to have problems with higher pressures.
Dugi
Car: dragging
just put some washers where the wastegate's bracket sits on the turbo. 2 or 3 washers on each other. won't cost you more then a buck
PDX_S14
Car: 98 240SX w/ sr20det
turbo xs. they work great.
