cheapest 5 lug conversion??
2.240s
Car: 240
Where is the best,cheapest spot to buy a 5 lug conversion for my s13, front and rear hubs w/bearingss14 spindles,front lower ball joints.???
rb20det_pwr
Car: skyline hcr32
aint nothing cheap man, i got mine for $360, which was a decent price, and then spent another $300 on brake pads and 5 lug rims..if i went back, i would just go all out putting new rotors, new pads, and braided brake lines at the same time..get it all outta the way for a while..
hannibal
Car: Red Line to Glenmont
Used S14 front and rear hubs.
The rear will bolt on. For the fronts, Ive heard you can press your S13 bearings into the S14 hubs and be all set.
chmercer
drill your 4 bolt hubs for 5 bolt, costs like 10 bucks. weld the studs in. done
2.240s
Car: 240
~4N~
chmercer wrote:drill your 4 bolt hubs for 5 bolt, costs like 10 bucks. weld the studs in. done
Are you serious? Did you do it yourself, or have it done?Also, would you happen to have any pics?
