cheaper FPR adapter
ca18det240hatch
Well, i just installed my universal FPR on my ca18det, and i found something out you may be intersted about. easier than having to buy an adapter for 35$, or having the ones that come with the univeral ones, leaking.
i took a stock sr regulator, im sure the ca regulator is the same. The part where you put into the rail, if you look down into it, theres like a valve that the FPR moves up and down, take a drill that size, drill down the center , shake out all the flakes, and voila, you have a hollowed out stock regulator that allows full flow of fuel thru it, which acts as....AN ADAPTOR....yayyyyyyy.
so all in all, i paid 30$ for the Megan racing universal FPR, and 0$ for an adaptor.
if anybody wants pictures, let me know,
driftin8ez
Car: 92 Coupe, Turbo Miata
good to know. However i have the megan fpr too and i'm using the adapter that the hit came with. It never leaks you just have to be sure to get the right size o-ring for it.
ca18det240hatch
hmmm good to know (=
