williamk10 wrote:I've used the stock jack many times swtiching from stock to summer wheels with no problems. Only complaint I have is I have to jack each corner to get each wheel out. I don't know why they couldn't put the jacking point in the middle
They didn't put the jacking point in the middle so owners wouldn't jack up the car and bust the tires/rims on the other side...
The max load for the ContiProContacts is 1168 lbs.
The Versa weighs about 2700-2750 lbs. Most users have additional items in the car + fuel. Do you really want to lift one entire side of the car and put that load on the sidewall of the tires?
As to the original poster... so the car leaned, then the jack gave way. I can't think of a single OEM jackscrew in all the vehicles I have owned that would be able to handle a car leaning away from the jack.
The static friction of the jack's base plate & the ground is the only thing that prevents the jack from leaning over when it is holding up a car. I don't see how you can expect it to laterally stabilize an object that weighs over a ton.
Cheap or luxury.
