S14slider09 wrote:def not coils as of right now. ill get those later. im still gettin use to the car. all i need is some new shocks and lowerin springs. thats it
In that case then KYB AGX struts with something like Eibach spring would do. The AGX is a more aggressive dampened shock. They are adjustable (Soft-Stiff) and can handle a higher spring rate than OEM. This setup wont go as low as coilovers but handle very well for the price. (You can get all 4 struts with Eibach sportline springs for around $729 maybe even lower). You can fit the AGX with lowering springs too, so its up to you. Or for even less money you could get the KYB GR2 struts. They are marginally better than OEM, but if you are gonna drift like you said, they won't work all to well as they can't really handle a higher spring rate than OEM. Best of luck in Japan
Modified by LugNut18 at 7:05 AM 4/21/2009
