Here's what I have to do this winter:Replace broken windshield $135Change diff fluidReplace belts, thermostat water pump, flush coolant (done)Replace trunk struts $30Replace rear speakers because theres more rattle then music nowWire the 2 dimmer switches I bought as rear window switches and put them in the OD light spot so i can get power mirrors later.
Other suggestions:New antenna, I got this and it works better then my old one ever did. Smooth, quiet, and great reception.
http://www.crutchfield.com/S-8...tenna
Got this and the green lights/black faceplate and silver accents looks fairly good with the stock dash black with green lights in the hvac unit above.|Its cheap and plays mp3 cd's and th radio. I didn't need anything else.
http://www.crutchfield.com/S-8...H2800
I've also replaced some missing smaller things that are cheap from the dealership like : the retainer strip for the boot behind the seat, some bolts for the headlights and a spring, new rubber bumpers for the hood so it would stop squeaking at every bump.
Wireless door lock kits are cheap.
Waterproof the top.
Change the fuel filter.
Install Hud
get power mirrors
get digital climate control
