Cheap manifold
Iscariot
Car: 1995 240SX
I have heard from many many places that the SSAC top mount is crap, and that the bottom-mount isn't much better, and I don't have the means to make a log manifold, so is it possible to use a stock SR manifold? CA? Also I heard somewhere that a Ford Probe turbo manifold would work?
PapaSmurf2k3
Site Admin
are you on a SERIOUS budget or something? there are pleanty of manifolds readily available for the 240sx. Also, which motor is it, KA24E or KA24DE, because there is a difference.
KA24E- o o o o (staggered)
KA24DE- o o o o (equi-spaced)
PapaSmurf2k3
Site Admin
ok the last diagram sucked balls... aparantly more than 2 spaces dont show up between O's
here is an E manifold
here is DE
Iscariot
Car: 1995 240SX
its a twin cam
and yeah, im on a serious budget
Bosrudorfer
Car: S14
JGS or bust!
PapaSmurf2k3
Site Admin
Bosrudorfer wrote:JGS or bust!
I agree. JGS is probably the cheapest relaible solution. If you dont have the means to weld it yourself, I beleive they can weld it for you, or just take it to an exhaust shop or something, itll probably run about $50
