Sometimes freeing up horsepower can be more benifical than adding a couple, so its something to still considernavysnail wrote:crank pulley frees up HP, it does not create it in any way. it allows the engine to rev up faster due to lower rotating mass.
I am probobly going to move this to 240sx tech in a little bit.
Cooling your engine with a tiny A/C fan is nothing but foolish and a really bad idea. Sure it might be fine for the winter/fall months, but will *not* adequatly pull enough air to bring down coolant temps sitting in traffic. That's a recipe for disaster. If you really want to remove the clutch fan(understandably, it can be loud as hell in the summer and cause a real drag on the crank) then do it properly with at *least* a set of Altima cooling fans. At least (one) out of that pair is designed to cool the main radiator.travis newberry wrote:if your car has or had ac you can use the AC fan to cool the engine. look at this...
Agreed with the small AC fan being the source of cooling being a bad idea especially with summer rolling around.slipnfall wrote:
thank you.Camel wrote:You are incorrect. The S14 ac fan will cool it sufficiently if it is running full time. I live in Atlanta, it has been through two summers now with no issues.
Chadd
