cheap : faster
mexor
i have a 89' auto fastback; i wanna make it faster ..for cheap though, that i can do myself. i unplugged the resistor thing (dunno how much that help, got it from FAQ) ..but what should i get for less than $100? intake or something? if so, is it hard to install? also is there that ECU chip that ive seen on ebay..does that work for 89's?
Daunttless
There isn't much that will make you faster for cheaper, especially in an auto SOHC. I"m sorry. : ( The best you could do is cut the bottom of your airbox out and see if you could get a custom exhaust for 100-200 dollars that's less crooked then the stocker. The ECU thing on eBay is a scam, I wouldn't suggest wasting your money on it. Good Luck!!
Infamous
save your money and go KA24E-T:D
FrEaK
Car: Boosted D21 Pickup
You could always advance the timing a few degrees see if you can increase top end power slightly
implict
Yea the Sohc doesnt cut it man, i just got rid of mine. Trust me you will save up like i did and get a sr :ylsuper
( well i hope:D )
FrEaK
Stop knocking the SOHC... theres plenty of potential in that engine, and it's simpler to work on then the DOHC talk to a couple turbo KA guys.. sheesh...
Megaseth
Car: 2002 Pathfinder SE
Freak has a good point. they make some monster SOHC turbo engines. thats about all they are good for though is turboin'
Silvia Tuner 1
Car: tuning
should have gotten the 5 speed at least.
