ScottJackson wrote:What's wrong with letting them sit on the pan? I know it's not good to DROP the engine on the pan (or even drop it at all). I've never seen a tight oil pan deform from having the motor weight on it. If it's an aluminum pan, it's a good idea to set it on something soft like wood so it doesn't have as much of a chance to crack (still very minimal with careful handling). Looks like a good motor to me. I'd like a pic showing the inside of the oil fill of the valve cover to see if it's clean or sludged up from poor maintenance.
I agree. For someone to go through the painstaking process of removing the engine with wiring harness right up to the ECU says something. I don't think they would have bothered had it been junk. Compared to some I see on Ebay, I'd be more inclined to take a chance on this one. Notice that the seller is savvy to the chain guide issue.
