Cheap Engine Managment
kingsoup
What do you guys think of this unit?
I found out through a thread on Supraforums that there is a computer uplink unit that controls fuel in 3D mapping and Timing, with a seconday any type injector set for, alcohol, propane, water. Whatever you want for 300 bucks.
It seems really amazing for cheap.
Heres the main site.
http://www.perfectpower.com/products/smt6.asp
Where too buy it fo cheap
http://www.tuningtechnology.co....html
A good discusion on the unit and pictures of software
http://www.yotatech.com/showth...=5130
I was thinking of this unit too control 550's on the SR. I haven't found out if it will handle a wideband O2 or not, but I assume it will.
Lemme know what you guys think!
kingsoup
Quote from Yotatech:
Quote »The 3D Maps can display live information as the engine is running. The software is available for download on Perfect Power's website. It can run in a "Demo" mode when the device is not attached. Also, the SMT-6 can log data for later play-back.
This little device is amazing. Since it can tune both Ignition Advance and Retard along with Air/Fuel Mappings, I'd be willing to bet that it's a one-stop shopping device to cure any and all tuning ills concerning the S/C'd engines. You will probably still need larger injectors. For the NA guys, it has definite potential to extract every last ounce of performance out of all your mods.
Here's the best part: It's only $250 Retail. This will work on ANY modern EFI Engine, OBD I or II. [/quote]I think this is the way too go for full CHEAP tuning for the SR and CA.
