TheOne™ wrote:hasn't it allready been said that 3" exhaust gives more power than 2.5"???????/i've seen a lot of threads sayin that, and always good if you're thinkin about turbo'ing.btw the integra does not have same engine as a 240sx.......so those graphs aren't really gonna do much on a 240 since its a way different engine.(bore/stroke).
A larger exhaust is always better, up until a certain point. For most "small" displacement engines, usually below 6.0l or 400HP, a 2.5in exhaust is sufficient. ANything larger then that and the leading edge(high pressure) of the exhaust pulse starts to weaken. And the trailing edge(vacuum) of the pulse begins to weaken also. And you don't want this to happen. The leading edge actually pulls the trailing edge along. And the greater the difference in pressures between the two edges, the less backpressure you get.
The problem with a 3in+ exhaust is that there is soo much surface area for the exhaust pulse to cover. This in itself causes the pressure difference to weaken
