Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Fri Sep 26, 2003 9:34 am
its not the same. you're talking about a 40mm 16 way adjustable(for example) alloy, full perch adjustable(IE, without affecting the stroke of the damper) true coilover, with dampening settings and stroke made for the spring rate and is probably rebuildable.
versus:
a sleeve that lets you adjust the lower spring perch, which may compress the stroke of the damper, and a damper that may, or may not, be ideally matched to the spring rate you pick, and is more than likely not rebuildable.
i'd say theres a signifigant difference.
also, the dampening is actually far more important to ride quality than you think. try riding in a car with 7kg/mm springs on soft (like 2 out of 16) you'd be suprised how easy it rides. set the damper to 15, and it becomes unbearable stiff....same spring rate.
-chet
