Cheap Chinese tubo kit + quality turbo
rider384
So, I was sitting around pondering about a KA-T motor, reading up on turbos for it.
The main problem I hear with these kits is the turbo is unreliable and even the manufacturer says that they have to be rebuilt ever 20k miles.
I see stock T25 turbos on Ebay for about 125 bucks.
So, could I buy one of these kits and just replace the cheap turbo with a T25?
Any thoughts on the subject?
Logan76
Car: Junk
The manifolds are prone to cracking, and all the parts are generally cheap junk, but hypothetically you could.
AZ89two4Tsx
On low boost, I'd trust a cheap manifold, but when you're trying for 300HP+, meh, I'd save up for some real parts.
But you're also going to need a bigger turbo than an sr t25.
480sx
Car: 1996 Pearl White 240sx
This idea works. The bottom mount t2 manifolds, especially when heat wrapped, have proven to be fairly reliable. Not saying they wont crack, but a lot of people have had success with them.
rider384
Thank you everyone for the good replies.
I guess I should have mentioned that I'm looking at running 11-12psi. I've heard the T25 is good to about 14-15psi.
Would the turbo manifold handle this well? Or would it be pushing the limit?
480sx
T25's become a heat pump over 12-13 psi, and shouldnt really be pushed past that. I have ran 14+ psi accidentally on my redtop down a strip once, and my IC and cold pipe were completely heatsoaked when i pulled around. Pretty cold day as well. Id keep it at max, 10-12.
Logan76
Car: Junk
^ I call bs, I ran my T25 at 31psi and made 478whp.
AZ89two4Tsx
No WAY dude!!! That's crazy.
Razi
Car: Moo
Logan.
WDRacing
Logan76 wrote:^ I call bs, I ran my T25 at 31psi and made 478whp.
And with that you get a new title...
Logan76
Car: Junk
aww brian, you honestly think that outdoes the last one? that's the best you've got? I <3 you.
WDRacing
It's actually accurate...which is why it's the best.
