96_240sxSE »
https://forums.nicoclub.com/96-240sxse-u9155.html
Tue Oct 21, 2003 12:15 pm
Quote »MOTUL, ford "high performance" is pretty good[/quote]
is this fluid readily available at your local auto parts tore (i.e, Pep Boys, etc.)? what's the going rate?
Quote »On a related note, beware of some of these folks selling 'Brembo' slotted and drilled rotors online. We have seen some cases where these rotors are tearing up brake pads on some applications. These shops are taking the stock style Brembo rotors and are drilling and slotting them in-house and selling them under the Brembo brand. The problem is many of them are not machined correctly and the holes and slots are not properly chamfered on the edges. This caused the edge of the slots to snag the leading edge of the brake pad compound and very quickly leads to pad failure and rotor failure.[/quote]
wow...i sure wish i could've seen/known this prior to purchasing my drilled rotors online (like 2 months ago...hahaha)! :doh let's hope the shop i bought them at (irotors.com) did the drilling RIGHT or else i'll be kissing my metal masters good-bye sometime in the near future. :xfingers hey grant...when you say "pad failure"...do you mean they will wear out REALLY FAST?? and as for "rotor failure"...wadya mean exactly?
jun
