Cheap alarm for 98 Grand Prix
Post all your Nissan electronics, car audio and stereo questions here!
Altiman94
Car: 1989 Nissan 240SX
My sister lost a spare key to her car at school. I would liek to find a very cheap alarm system for it just for safety measures. I'm not looking to spend any more than say 150 or so with everything installed. Just a cheap-o alarm, that's all. It doesn't have to be anything fancy.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Check out the ones at Circuit City. Cheap ones are available.
Rex
Car: None
It may just as cheap to change out the door tumblers, check a salvage yard. It may get pricey if you wanna change the ignition as well.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
The Pontiac vehicles have the passlock or passkey system as an option. If your sister's car has it. Go to the dealer! have a new key programmed and all previous ones not in use deleted. if no pass system is installed this does not apply. As for cheap alarms? You could probably get one installed in that vehicle for less than $200. There is more labor required on most of the pontiac vehicle than the regular GM cars to install alarms. Check out the Avital model 2200. Good basic alarm and has onboard failsafe starter interupt circuit that prevent unwanted starting of the vehicle. good luck!
