hsckris »
https://forums.nicoclub.com/hsckris-u42810.html
Wed Sep 12, 2007 9:19 am
basically all the bolt-on upgrades possible are (give or take):
air intake/air filter -- been discussed. good for a few hp.spark plugs/wires -- more/better spark=better efficiency at burning the fuel charge, which never hurts. also, indexing your plugs is sometimes good for 1-2hp. generally though won't give the vehicle more horsepower and torque, but it will improve the way your ignition system functionsignition -- same basic effect as above, to a great degree, but also depends on what you do (timing adjustments or not or what)exhaust/muffler -- been discussed; i agree that dynomax is best muffler if you are going muffler shop built route.cat. converter -- don't underestimate this, my brothers car picked up a good amount on the "butt dyno" with a high flow catprogrammers/chips -- can give more power, don't know if its available for a 3.3thermostat old hot rodder trick... i wouldn't recommend if you live in a real cold place or getting too low of a temperature maf sensor good for power on some vehicles, not sure if its available on the 3.3headers downside is it'll add sound and can reduce low end power. upside? usually more hp/tq at high rpm.injectors you probably won't really benefit from this without doing something more serious (s/c or nitrous or something)pulleys this will slow your accessory drive, but sometimes is good for 10hp or so.intake mani porting, port matching, extrude honing are all good things to do (since i don't think a replacement one is available for the xterra). nissan perf. mag got 12hp out of a measley 1.6 liter sentra motor just with extrude honing.e-fan i think the x has stock one, but if not its worth a couple of hpand of course, the big boys nitrous and s/c or turbo. if you really want to boost power, this is the way to go. doing so can adversely affect engine life, but honestly since the 3.3 was available in stock s/c form, if you went with a mildly upgraded version of that you'd probably be good to go.
internals (like new pistons and boring out the motor -- mentioned earlier) and even camshaft changes and things of that nature when combined with some of the above mods will result in the most power possible.
bottom line: i think if it was me, i'd make it s/c and do the pulley upgrade. and then slowly upgrade everything else listed above. if you have an auto trans, you may want to watch throwing this much additional power at it without upgrading it. for a manual, you'd probably just need a new clutch.
