that sir depends ENTIRELY on the particular turbo.....nelson8708 wrote: If your only running 9psi you'll be fine if you get a set of sr 370's.
-Nelson
Not the best for atomization is an understatement. A fine mist of fuel is key during the combustion process. When you file the tips of the injectors off it becomes a stream...F that. RX7 injectors can be found all over for cheap. WAY better option then chopping the stockers up and IMO ruining them.nelson8708 wrote:you can mod your stock 270's into 550's if you want. Not the best atomization but, it'll get the job done (its what i'm doing). Do a quick search and you'll find it. If your only running 9psi you'll be fine if you get a set of sr 370's.
-Nelson
Sounds like a great deal right there!ashibah83 wrote:that sir depends ENTIRELY on the particular turbo.....nelson8708 wrote: If your only running 9psi you'll be fine if you get a set of sr 370's.
-Nelson
i got a set of STI injectors for $120 cleaned and flow tested, you can get them new in the $170 range
i was going to suggest that. i bought a set of venom 550cc injectors, and i did a little messing around with the stockers, only to find out thats what they did.nelson8708 wrote:you can mod your stock 270's into 550's if you want. Not the best atomization but, it'll get the job done (its what i'm doing). Do a quick search and you'll find it. If your only running 9psi you'll be fine if you get a set of sr 370's.
-Nelson
wd i believe you, but have you actually seen this filed tipped injector on a flow bench? im curious how "straight stream" it actually is?WDRacing wrote:Not the best for atomization is an understatement. A fine mist of fuel is key during the combustion process. When you file the tips of the injectors off it becomes a stream...F that. RX7 injectors can be found all over for cheap. WAY better option then chopping the stockers up and IMO ruining them.
Just my .02
Link?ashibah83 wrote:you can get them new in the $170 rangenelson8708 wrote: If your only running 9psi you'll be fine if you get a set of sr 370's.
-Nelson
