chassis flex
barrigas14
alight i have been bating this around for some time. within a year or so i am thinking of getting a vert of some kind. i am looking for something cheap and RWD, so that gets me to older miatas and the 240. now my only concern about the 240 is that of chassis flex.
now i am been in a convert tang and it was alight...but i am also been in a miata and i thought holy ****. now, how bad is the 240? i would be not roadracing it but i would like to take it through turns and what not.
maybe i will just hit up greg and test his car
240droptop
Car: 93 240sx Convertable
Not gunna lie to you theres flex.
A few inextpensiive mods will make a vert ALMOST as solid as a coupe.
You're welcome to drive mine, it's solid.
ramrat
AZ can you fill me in what what mods i need to tighten up the flex.
Thanks!
barrigas14
ramrat wrote:AZ can you fill me in what what mods i need to tighten up the flex.
Thanks!
werd
btw greg, i might hit you up on that offer at the Nissan Nationals
Most of the flex is in the cowl - Easily remedied by a triangulated strut tower brace.
CP Racing makes one, sometimes they have them on ebay, like $100.
Another thing you can do is the door conversion. Won't reduce flex, but they're lighter and reduce the "perception" of flex (less noisy).
Look for a HICAS rear sway bar, some good springs and struts, and some good wide rims / tires.
Hijacker
Car: '92 240sx Convertible
'94 F-150
cowl shake seems to be the biggest complaint in these verts. I've never had that issue though.
The car is very solid from front to rear. I had the car on stands on day, and it was sitting off of one from where my floor was dipped a little. Crossways, it needs a little help. A triangular strut bar is the biggest help, with a close second being a rollbar (which would be added safety to put in anyways)
barrigas14
i wonder if these would be better than the CP strut bar.
only thing i don't like about the CP design is that when i slap a huge turbo on there it might inpeed on it.
btw plans for a vert is to make it a nice looking car...either Silvia front end or S15 front end. with at least 400rwhp.
nab911
Car: 93 Nissan 240SX SE
I went out with my vert the other day to kick it sideways a little bit and after i while i looked up and the rubber piece lining above the windshield was cracked. Not sure if it was like that or if i did it but now it makes me want to get another cp racing strut bar asap.
Hijacker
'94 F-150
if it's the piece i'm thinking it is (it's more solid than rubber and you can see it even when the top is up), it's designed with a slit in it. Plastic and rubber shrink and expand as temperature conditions change, so that piece was designed with that in mind by being a two part piece. After a while, it just shrinks a bit and looks like it's cracked.
nab911
I wish... there is a real slit over towards the middle but this is right where the driver visor is and it is a crack.
ARKE4031
Car: 94 240 SX CONVERTABLE
Hey Hitman,
I also have a vert as well as a coupe. I find the vert very loose in the front. Where can I gewt these triangular strut tower brackets? What does cp performance parts stand for or what is their web address? Do you think it will also help to install a strut tower bracket that extends over the engine from one tower to another?
nab911
CP racicings site is like http://www.cpracing.ca i think. Google it if thats not right. They are expensive but WELL worth the price.
Arke - The CP bar is sometimes available on ebay, search "240sx bar". I paid $100 shipped.
It not only ties the struts together, but also braces through the firewall.
ARKE4031
that sounds like it will tie everything together very well
