okis14 wrote:I've never seen anyone do it and I've heard that if water gets in there it has a more % of rusting.
It makes sense and in your case you probably could care less.
Does that even help that much. I wound assume it helps a little but can it even be felt?
but if the frame is filled with foam, wouldn't that prevent moisture from settling within the framework? i want to know where you heard about that.
if you use POR-15 prior to filling, im sure it would keep most of the rust off.
toptechracing wrote:Tap plastics.....It has been done to my racecar. Not sure the gains were all that...It will cause issues when you have to make repairs.
what kind of issues do you mean? isnt the foam degradeable in case chassis repair is neccessary? what is the name of the foam?
