daegrigg »
https://forums.nicoclub.com/daegrigg-u30902.html
Tue Jan 24, 2006 9:43 am
'Been chasing this gremlin since I bought the car 6 months ago.
Classic bad idle with poor performance especially below 2000 rpm. Failed the smog test with excess HC and NOX.
Poor gas mileage.
Cleaned and cleaned the MAF and throttle body. Cleaned contacts, etc.
Three injectors testing at 48, 19, and 18 ohms respectively.
(Suspect the injectors)
Could coil packs or plugs be in play? Is there a non invasive test?
Does not feel like knock sensors - based on experience with my wife's J30 where we had to replace them.
Have not read the engine codes - assume would have to take it to a shop for this.
SO THE BIG QESTION IS:
If it is the injectors, how can I be pretty sure of this before tearing into the engine.
Thanks for the thoughts,
Don
