numbnuts240 »
https://forums.nicoclub.com/numbnuts240-u42843.html
Tue Feb 16, 2016 5:25 pm
ok, this isn't for a nissan. but problems and codes are generally universal.
my 99 explorer with 4.0l v6 (vin x/ohv) 188k miles, is throwing lean codes for both banks p0171 and p0174. i'll provide some background info:
the exhaust terminates with a turn-down right after the downstream o2 sensor after the cat.
the codes originally came one leaving a scrap metal yard, which was wet and muddy.
at the time, the exhaust pipe was maybe an inch long after the o2 sensor.
the sensor was sprayed with cleaner and a turn-down end welded on.
i've experienced hesitation from time to time. there was one day when it was prevalent on the highway, 4hi engaged during a rather crappy commute. beyond that, maybe once a week. feels like a big jerk.
i cleaned the maf to no avail.
i sprayed carb cleaner around the intake manifold and didn't get any change in idle.
i've hooked up a scanner on 3 different occasions. 2 out of the three showed higher than normal fuel trim levels.
the 2 higher readings at idle:
long term bank 1: 5%
long term bank 2: 3%
short term bank 1: 0%
short term bank2: 0%
at 2500rpm:
long term bank 1: 9%
long term bank2: 7%
short term bank 2: 0%
long term values increase when i step on the gas sharply. they also increase letting off the throttle after holding at 2500rpm
o2 sensor values at idle:
o2 bank1 sensor1: 0.7v
o2 bank2 sensor1: 0.7v
02 post cat: 0.2
o2 sensor values at 2500rpm:
o2 post cat: 0.13
my next test is to test voltage at the maf. i don't have a fuel pressure tester, which i can get, but i want to rule out everything else before i go that route. i'm hoping someone here has some insight of things to look for or check.
numbnuts240 on Tue Feb 16, 2016 5:50 pm, edited 1 time in total.
