Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Mar 26, 2004 6:16 am
That why my home garage looks like a dealer parts department. When we strip cars I always get the things that never fail [which are not kept in stock]. Why keep that it never fails! Someday it willI swore I would never let the Q get towed in for anything, again after the stainless steel brake line failure of a few years ago. It may drive into T3 limping a little sometimes. Since I am not the best at replacing things, I always like the assurance that the Master techs are there if needed for advice or to laugh at my contortions with my bag of tools.......I carry around 100 pounds of test equipment, gauges, fluids, bulbs, and spare parts in the trunk. ECU, TCU, FPCU, MAF, CAS, TPS, Ignition modules, coil pack, AC control head, lots of misc and jumper wires, duct tape, and a gallon of distilled water.....etc.
The are so many modules and components that never [at least in 14 years] fail on a Q it is amazing..........I'm sure that will still be the case in a 20 years old unit.
Electronic modules are vibration sensitive so tire wheel balance is important.
2 days ago was the first non crank situation since 1994 when I left it too long at an airport........I've come close a few times [with batteries] but now I just replace them every 36 months on the dot........... early December.
My tire jack has never been used........neither has the spare [rottten by now probably].
