Chase Bays RB20DET, RB25DET, & RB26DETT Engine Harness
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
Chase Bays
Car: 1989 Nissan 240sx, 2004 Mitsubishi EVO 8, 1995 Lexus LS400
We’ve got some great harnesses to show you. A close race in some of the most requested harnesses to be produced by Chase Bays, and here they are. We've integrated so many features into this harness, this kind of innovation and flexibility has never been doing with an engine harness in our industry.
Even though the RB engines are remotely the same harness build, there is about 30 electrical variations. Variants include, coil packs or spark plug wires, coil igniter or integrated igniter, crank/cam sensor & pickups, different ECU’s, injectors, VTC valve, and a few others. We’ve done the research and become very familiar with these variants. So even if you’re not familiar with the electrical components, we are. The harness can plug into, basically anything. We use the same black 16pin connector near the ECU plugs on all of our harnesses. It has all the chassis inputs and outputs you need. The opposite side of this connector is what we adapt to YOUR chassis. When ordering this product on our website it will ask you all the info we need to know via drop down menu’s. This is all the innovation and flexibility mentioned above. This knocks out 20 birds with 1 stone, or harness :)
http://www.chasebays.com/product/nissan ... an-rb20det
CM1 - $649.99
CM2 - $949.99
CM Mil Spec - $1,349.99
http://www.chasebays.com/product/nissan ... an-rb25det
CM1 - $649.99
CM2 - $949.99
CM2 - $1,349.99
http://www.chasebays.com/product/nissan ... n-rb26dett
CM1 - $699.99
CM2 - $999.99
CM Mil Spec - $1,399.99
Find out more info on these harnesses by clicking the links above
Return to “Advertisers' Marketplace!”
