Chase Bays 1JZ & 2JZ Engine Harnesses
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
Chase Bays
Car: 1989 Nissan 240sx, 2004 Mitsubishi EVO 8, 1995 Lexus LS400
This has been one of the most requested harnesses to be produced by Chase Bays, and here it is. There are so many features the 1JZ/2JZ has to offer, this kind of innovation and flexibility has never been done with a wiring harness in our industry.
The different engines we cater to are remotely the same harness build, but there is about 20 electrical variations. Variants include, coil packs or spark plug wires, coil igniter or integrated igniter, crank/cam sensor & pickups, different ECU’s, injectors, VVTi, and a few others. We’ve done the research and become very familiar with these variants. So even if you’re not familiar with the electrical components, we are. The harness can plug into, basically anything. We use the same black 16pin connector near the ECU plugs on all of our harnesses. It has all the chassis inputs and outputs you need. The opposite side of this connector is what we adapt to YOUR chassis. When ordering this product on our website it will ask you all the info we need to know via drop down menu’s. This is all the innovation and flexibility mentioned above. This knocks out 20 birds with 1 stone, or harness :)
CM1 - $699.99
CM2 - $999.99
CM Mil Spec - $1,399.99
Find out more info on these harnesses here:
http://www.chasebays.com/product/nissan ... ge--2jzgte
Return to “Advertisers' Marketplace!”
