Charlotte NC, and no first gear
chandler
Car: 91 civic hb & 96 S14
hey guys, it must be that time in my cars life that its just begging for attention, now I change my oil regularly, I change my gear oils too, but after I parked my car at my work for lets say 2 hours. I got back in and the clutch pedal was a little lower than usual ok maybe I need a new clutch no biggie, just wait till pay day, order one and boom got a new one. well pay day is a week off, and if you remember the problem with my header breaking(search) you know no small problems happen to me.on the way yo work the next day, it wouldnt go into first. I dont mean sitting still , I mean at all, I had to cut the car off and put it in first and crank it up. now traveling through rushhour on harris from mallard creek to albemarle is hell any way, with no first, it was like working at an izuzu dealer, it sucked azz. well my storuy ends on a slightly lighter note. I get to put in a new master, slave braided steel line, clutch fork pivot, clutch and my fidanza thats been sitting at home.......... now only if I had that turbo..................
Silvia007
Car: 93 Nissan 240SX SE Fastback
My transmission does that too. I don't have to kill the car entirely though. What you can try is this. When you come to a stop, you can go into neutral but before the light turns green, or when the other light turns yellow, push in your clutch and hold it. When your light turns green, put it into gear, it works great for me. If I step on the clutch and try to put it into first gear, it will not go in without pounding the sucker in there. For stop signs, push in your clutch and leave it pushed in even if you're in neutral, when you come to a complete stop put it into 1st and drive off, it should work, if not, you may need a transmission rebuild.
daniel240
Car: cars/motocross
also if your slowing down for a stop, shift it into 2nd before putting it into first. that seems to help it go into 1st easier.
chandler
you dont seem to understand, no pedal, no that it wouldnt go into first, just no pedal.....
chandler
got some of my parts nfrom spl, man are they nice, steel clutch line piviot and speed bleeder
Nismo240s
Car: 92 240sx SE, 96 Maxima GLE, 05 Titan SE
mallard creek and harris... man you must live right down the road from me...
chandler
I live off of reames rd, but unless I am standing at the end of the driveway you wont find my house ...=)
Sykikchimp
wow.. charlotte folks..
I'm in south charlotte, behind the arboretum. I used to live on Harris. Right by University place.
chandler
I used to work at that walmart, man that sucked, If yall ever need a hook up on tires and such, I work at the tire kingdom on albemarle, just give me a holla, and ill see what I can do for ya aight
chandler
well, lets see, got yelled at by the boss cause my car was taking up room in the lot, so I was like lets see if I can install the master and slave cylinder and see if it runs a little better, well the braided steel line and the speed bleeder helped a bit also, the master cylinder was broken, no tthe cylinder itself the pivot on the pedal broke off, man that sucks, any ways just tellin yall the jist of whats happened thatnks yall, if ya live in nc and want to see some cool parts just give me a holla
DriftinNC
Car: Sr datsun 510
whats up man? I llive in kernersville, its a little town inbetween Highpoint, Greensboro and Winston-Salem... its only like an hour from charlotte. Merchants Tire Kingdom attentant here also, its pretty nice getting free used tires, also free mount and balance. Which side of charlotte you live in?
chandler
i live on the north side, and I have to drive through university every day to get to work, now all I need is to get that resonator welded in so im not deaf from the drive
methodchris
word, i go to UNCC ..lot of charlotte people on here
chandler
if you need tires and such man just hit me up ill get ya a deal
